4 Pages«<234
wishnia
#31 Posted : Saturday, December 15, 2012 1:01:56 PM(UTC)
wishnia
Thank You... Didn't know that existed. found 3 boy scout rank patches (wondered where they went?) $3.12 in coins and countless tiny lego parts. Turned the machine on right afterwords and she is running great.... :)
Tyeschultz
#32 Posted : Sunday, March 17, 2013 3:13:48 PM(UTC)
Tyeschultz
Whirlpool Duet Washer Model GHW9150PW0
F/H code appears ~10 minutes after starting normal wash cycle, pressing the cancel button and pressing start continues the wash cycle with the same F/H code appearing after several minutes.
Cleaned the entire drain pump assembly, large item filter & bottom drain boot (with big ball), verifying drain and spin cycle works correctly (pumps water out the elevated hose with no issues).
Can you confirm that I need to replace the pressure switch and / or
flowmeter (are these the correct parts), when will the pressure switch be available?
Flowmeter
Part Number AP4310720
MFG Part Number W101102
Switch-Wl
Part Number AP5669582
MFG Part Number W10514214
#33 Posted : Monday, March 18, 2013 12:37:30 PM(UTC)
Hello,
I don't think it has something to do with the flowmeter. More likely the problem is a bad pressure switch and/or pressure hose. I would recommend to check the pressure switch as instructed in the attached file before you order it. The pressure switch Part number: W10514214
you posted is correct.
The pressure hose Part number: W10004260
You have to speak with the APP customer service regarding the part availability.
File Attachment(s):
Testing pressure switch.doc (334kb) downloaded 21 time(s).
smcdaniel8190
#34 Posted : Friday, January 10, 2014 10:06:17 AM(UTC)
smcdaniel8190
After replacing the pump it still wouldn't drain. Thought about it for a couple of days, verified that the pump was working as it should and thought that it might not be getting any water.
Took off the piece coming from the bottom of the tub (where there is a ball float valve) and it was completely clogged with a HUGE hairball.
Wash, rinse, repeat -- works like brand new now.
4 Pages«<234
