Amana washer leaks water onto floor. I flled it and checked it 30 minutes later without running it. About a 1/2 gallon of water had leaked out. I need to know if the outer tub is cracked or if the hose leaks. How do I find out?
Take out the two screws that hold the front panel at the bottom and operate the machine. Watch it closely and it will be obvious where the leak is.
Good luck
