beek56
#1 Posted : Monday, March 26, 2012 6:10:14 PM(UTC)
beek56
I OPENED UP THE GAS DRYER TO REPLACE THE BROKEN BELT AND TENSIONER PULLEY, I ALSO REPLACED THE WORN OUT DRUM GUIDE SLIDES FOR ABOUT THE 3RD TIME. AFTER I OPENED UP THE INTERIOR I VACUUMED OUT THE COMPLETE INTERIOR USING A BRUSH AND VACUUM. AFTER EVERYTHING WAS CLOSED UP I TURNED ON THE DRYER EVERYTHING WENT ON EXCEPT THE HEAT. WHAT HAPPENED? THE HEAT WORKED BEFORE.
THANKS IN ADVANCE
BEEK :confused:
beek56
#2 Posted : Monday, March 26, 2012 6:46:42 PM(UTC)
beek56
THANKS IN ADVANCE
BEEK :confused:
Read more: http://forum.appliancepartspros...ement.html#ixzz1qHOk2Q5P
http://forum.appliancepartspros.com
EmmaMeal
#3 Posted : Monday, March 26, 2012 9:11:45 PM(UTC)
EmmaMeal
Sorry, didn't catch that. Say it again, a little BIGGER!!
