geniustff
#1 Posted : 13 years ago
geniustff
My whirlpool fridge leaks from the bottom of the freezer and its not from the connection to make ice. Wondering if any know what could be causing this to happen and how to stop it.
#2 Posted : 13 years ago
Pull out and remove the freezer drawer and check the drain (under the evaporator coils). Use a hair dryer to defrost it if it's frozen. Blow some air through the drain and run hot water to make sure it's open.
