I have the problems listed in the title. I've looked at several threads and I'd like to confirm what the problem could be. Other than the control board, I've seen reference to some other switches. I don't want to replace the wrong part and don't want to replace the control board if it's not the problem. Indictor lights work and I've tried to reset the filter. Just no dispensing and no light for the dispensing panel. Please advise.
Groups: APP Team
Hi. If there is clicking sound when you depressing the water or ice lever coming from the back of the refrigerator and nothing works - then most likely it's the control board. The control board Part number: AP4436216
The clucking is not related to trying to dispense ice and water. It clucks randomly and not when the refrigerator is running. Do you still think it is the control board and not a switch?
Groups: APP Team
Hi. Most likely it's the main control board. You can return any unused parts, even if they has been installed.
Thank you. Post the results.
