GIFFORD95
#1 Posted : Sunday, January 13, 2008 8:51:37 PM(UTC)
GIFFORD95
My refrigerator has been leaking water on the bottom under the crispers for about a month. I suspect it is a cloged drain but am not sure how to get to the drain to unclog it. My freezer is on top and I think the drain is up there somewhere but I'm not sure how to take the ice maker off to pull the back panel of freezer off on the inside.
#2 Posted : Monday, January 14, 2008 4:20:42 PM(UTC)
The drain is located under the evaporator coil in the freezer.
In order to get access to the drain you have to remove the freezer floor (#25 on the liner break down diagram) and the evaporator cover (#16 on the liner break down diagram).
To defrost the drain and clean it you can use a hair dryer and hot water.
- Here are the break down diagrams for the Whirlpool refrigerator Model ET1NHMXKT00
Good luck.
water in fridge (Refrigerator & Freezer Repair)
by iggy216 5/27/2012 11:10:18 AM(UTC)
leaking icemaker water in fridge (Refrigerator & Freezer Repair)
by pgtek2001 11/7/2011 10:40:48 AM(UTC)
by captom 7/29/2009 10:11:48 AM(UTC)
