Hello, I have a Kenmore Gas dryer that won't heat. The ignitor glows and the flame ignites at start up. On the next heat cycle the ignitor glows for about 10 seconds but no flame! If you let it cool or sit for awhile it does the same thing, heats up initially then next cycle the ingnitor just glows for a few seconds or so. Is this a gas valve coil problem? If so, does appliance parts pros have them? Thanks in advance for any help!
I am having the EXACT same problem. Now what to replace; the part if determined or the dryer.
Originally Posted by: jack25914 I am having the EXACT same problem. Now what to replace; the part if determined or the dryer. jack, I replaced the "GAS VALVE SOLENOID COILS" they come as a kit. APP did'nt say if they had them so I ordered them from Repair Clinic.com, the cost was $20.05 + shipping. That bad boy is running good now!!!:D
