(age is a guess - may be slightly less)
Came home today to find wet floor. Tub empty, but not sure if leaked out or was spun out - husband says he heard it spinning and clothes were not abnormally wet. Where is the best place to start in diagnosing the problem?
Thank you.
Take off the front panel (two screws at the bottom) and observe the machine through the wash cycle. The source of the leak will be pretty obvious.
Good luck.
