maximum destruction
#1 Posted : Sunday, January 13, 2008 12:02:40 PM(UTC)
maximum destruction
Hi Guys may not be right place to post, just want an expert opinion.
I replaced a set of lavoritory taps today (washerles design) when I attached the flexible braided pipe to the taps, the soft copper line from the Faucet twist a little ( sometimes have a tendency to overtighten). I did not try to back it off and it is working great. Should that be OK.
Maximum Destruction
#2 Posted : Monday, January 14, 2008 1:42:32 AM(UTC)
Should be ok. Remember, there probably is a soldered joint where the copper pipe mates with the valve body. Any more twisting may damage the joint.
maximum destruction
#3 Posted : Monday, January 14, 2008 11:47:52 AM(UTC)
maximum destruction
Thanks for your advice richappy, I appreciate it.
Maximum Destruction
