Profile top freezer mode. The freezer/frig compartments go warm intermittantly (over last month) Has gone to point of melting freezer food. If I unplug for short time, I hear compresser kick in and it returns to normal operation. Had appliance guy out but it was ok at the time of service. He suggested mother board. Is this a common failure for intermittant issues?
Did you notice when it is not working if the compressor is off and the both fans are working. If so this is almost always the main board especially if it is intermittently working. Pull the main board off and look on the back of the board for a bad solder joint. If not there is a bad relay on the board. Refrigerator repair guide
Thanks applianceman. I did note when the compressor off, fans are working. I have looked over the back of the board and thinks looked ok...I will do a closer investigation before I replace the board. Thanks for the quick reply. Dobber
I have the exact same issue. Did you try to replace the board? Did it work?
Thanks.
Lennyz Seems to have worked. I ordered the part, waited 2 weeks to see if problem would repeat and observe if problem corrected. Got tired of waiting so went ahead and replaced. Temps now more stable, not seeing the fluctuations. Hope that helps. dobber
