chubS01
#1 Posted : Monday, August 17, 2009 3:24:45 PM(UTC)
chubS01
My dryer will not tumble and I have already raised the top and found that the belt is torn. I have a replacement belt but I don't know what to do next or how to go about replacing the belt. Do I need to remove the drum to do this? Are there any free repair manuals or really good step by step instructions?:(
sidfink43
#2 Posted : Wednesday, August 19, 2009 9:27:12 AM(UTC)
sidfink43
I don't have a manual for your model, but this should not be difficult if you just take your time. You do not have to remove the drum.
Take off the front panel and you should have access to the motor and belt tensioner. Place the belt around the drum and disengage the tensioner to get it around the tensioner and on the motor pulley.
Test to the see that the drum turns, and if so, put it back together.
Good luck.
