dougbayer
#1 Posted : Sunday, January 13, 2008 7:47:22 AM(UTC)
dougbayer
Kenmore dryer. Worked this am until I switched loads. I pushed the start button and nothing happens.
ripleys
#2 Posted : Sunday, January 13, 2008 5:12:51 PM(UTC)
ripleys
Pull the back off the dryer and look for the high limit fuse (down near bottom, white with two wires going to it). Pull the wires off, join them together (make sure they are secured away from any metal) and push start. If it starts, replace that part and ensure that your external vent is clean and your outside vent damper is opening properly.
