firstsamuel3
#1 Posted : Monday, August 17, 2009 7:49:14 AM(UTC)
firstsamuel3
My dishwasher is stock #17829, Type #279-2, Serial #FP2642039, Mod #665.178290000. I hooked up and plugged in my dishwasher. I pushed start and the cancel/drain light lite up and it started to drain. For some reason it will not go into start mode. None of the other lights lite up except the cancel button. I was told maybe the board needs to be replaced. If this is the problem where can I find a repair manual or instructions? Can someone help me with this?
#2 Posted : Monday, August 17, 2009 4:17:57 PM(UTC)
Most likely the problem is a bad key panel which is a part of the control panel. If you need the correct part number then post the color of the control panel.
firstsamuel3
#3 Posted : Monday, August 17, 2009 5:42:11 PM(UTC)
firstsamuel3
The color of the control panel is tan or almond in color. Can you help me find the part number?
Thanks,
Sam
#4 Posted : Monday, August 17, 2009 6:04:10 PM(UTC)
Hi Sam,
The control panel (almond) Part number: AP3138916
You can talk to the Appliance Parts Pros team regarding the ETA for the part.
