joker472
#1 Posted : Thursday, March 22, 2012 7:23:59 PM(UTC)
joker472
I have a problem with the fridge not cooling in FF side and the freezer coil is frosted up. I have read through other post and checked the defrost heater and thermostat and they can back good(i think) the DT on my meter was .07 ohms but that is what I get touching the the leads together on my meter must not zero out. The heater was 23.3 ohms. So I think they are both good so I tried to use terminal L1 and test on the ADC to force it into defrost mode and I get nothing no clicking noise and the fans or compressor dont shut off. (Is my ADC board bad or something else). What could be the problem or what else can I check to narrow my problem down.
some other info on it. The fridge is running all the time and will not shut off at all, I have heard a buzzing noise in the FF side of it from time to time before I started having the problem with it freezing up and not cooling.
PLEASE help me find my problem I dont know what else to try and cant find anything else to try.
thanks, for any and all help on this.
joker472
#2 Posted : Friday, March 23, 2012 12:06:54 PM(UTC)
joker472
just updating I came home from work today and the freezer was about 9 deg. and the fridge was about 38 deg. i have been trying to get the temp in the freezer raised some i thought that maybe it was trying to cool to much and causing it to freeze up so I turned the control down and went to far and it must have been in the off position because the ADC board was making a buzzing sound and the fans all shut off so it must have went into defrost mode RIGHT? I am guessing that my ADC board is bad does that sound right to anyone???? I forgot to add that when the ADC board started making a buzzing sound and the fans shut off I check it a few seconds later after it quit buzzing and the defrost heater was working fine.
Thanks for the help ANYONE
