ndquale
#1 Posted : Sunday, August 16, 2009 7:46:26 PM(UTC)
ndquale
I have about a 6 year old Atlantis washing machine that didn't drain. In searching for a problem I looked underneath it and saw that a belt had came off it. The belt appears to be in good shape however just not attached. I'm not familiar with them but I'm assuming I can take off a side panel and put the belt back on? That would be part of my draining problem or do I have possible bigger problems?
Thanks, Nathan
Frank / APP Team
#2 Posted : Monday, August 17, 2009 4:41:07 AM(UTC)
Frank / APP Team
Thanks, Nathan
You can put the belt back on by simply leaning the machine back. You'll see the pulley's underneath the belt goes around. Make sure you hand turn all the pulley's to make sure they all turn freely. The motor should be on a slide tensioning device which keeps proper tension on the belt. The front comes off if you do decide to have a peek at the working components. Could be you just need a new belt. Below are pictures of the motor tensioner spring and and belt.
Part number: AP4027842
