mrsross2010
#1 Posted : 13 years ago
mrsross2010
I have an amana dryer that is just barely over a year old. Last night it started making a buzzing noise when the start button is pushed but only on high heat timed dry and the high heat setting that has the energy saver setting on it. It will turn on and spin on the timed low heat setting but doesn't warm up and dry the load....I just paid off my rent to own on less than a week ago :(
#2 Posted : 13 years ago
A model number may help others help you.
I am not sure hoe rent to own works but I would check the contract to see if you have any warranty.
