jkordzi
#1 Posted : Saturday, January 12, 2008 12:43:52 PM(UTC)
jkordzi
Recently, the heating element blew when a fork landed on it while it was heating and caused it to crack. I replaced it but it doesn't get power at any time during the cycle. The hi-limit thermostat has continuity. I can use a DVOM and solder and I've had the control board out before for another issue, so if it's the control board, I'd appreciate specific trouble shooting directions. Thanks.
#2 Posted : Sunday, January 13, 2008 1:36:22 AM(UTC)
Per the schematic, check the control board output pin that supplies voltage to the heater. If no voltage=bad board. You might want to check for a fused open ribbon on the board.
jkordzi
#3 Posted : Sunday, January 20, 2008 5:03:38 PM(UTC)
jkordzi
Finally got around to doing the repair. The back of the board had a fused ribbon like you said. Bypassed it by soldering a short piece of insulated wire across the fused section, but still didn't work so will get a new board - must have blown one or more of the solid state components on the board. Thanks.
