:confused: HELP --Dryer will not turn on. tested all parts with ohm meter (husband said everything good) door switch clicks,motor turns freely,belt was not broke,talk with local repair guy- he suggested to remove timer and if it rattled it was bad. removed - timer has a rattling noise when you shake it. I'm looking for confirmation before i spend $$ to replace since most of what I've read on site, this is not a common issue. I know the outlet is good because their is a older dryer working just fine plugged in here. someone gave me this dryer because it would not work and is a newer one than mine. ANY ADVICE ?????? THANKS IN ADVANCE
