wishfully17
#1 Posted : 13 years ago
wishfully17
no lights on at end of cycle... opened, water did not drain. took inner parts out to clean in case there was a clog.. nasty cleanin'... put all back together and turns out it probably was not clogged.
tried to turn it on.. .no lights... dead?
suggestions? fuse? any other possibilities and/or troubleshooting tips?
#2 Posted : 13 years ago
Unplug the dishwasher power cord and check for 120 VAC at the wall power outlet.
Remove the bottom panel. Remove the terminal box cover and check the power cord connections. Make sure the hot (black) wire from the power cord is connected to the hot (black) dishwasher wire.
Open the control panel and check the door switches.
Check the control board thermal fuse (#6 at the diagram) for continuity.
- The thermal fuse kit Part number: AP4423189
