1. i got "LD" which means washer is taking too long to drain. 2. pressed stop.. got 9 mins remaining 3. got "LD" again 4. removed clothes 5. tried to get it to run rinse/spin.. nothing 6. tried different cycles... nothing 7. unplugged, plugged back in tried 5&6 again.. nothing lights work, washer does nothing.. wont run
history- i replaced drain pump last year after water spilled out the bottom all over the floor. turned out the drain pump had a hole in it. new part was reinforced where the hole was.. guess it was a common issue so they improved the part.. anyway... lid light does not come on - maybe its the lid switch?? looking for more possibilities and/or troubleshooting suggestions before i tear the thing apart and buy something that doesnt fix the problem. i cant find lid switch part on this site.
Groups: APP Team
Hello. The LD means long drain, but is there any water seats in the tub? If yes- check if the pump is working, any restrictions in the drain house? When you raise the top locate the manual on the one the walls. Run the diagnostic test.
Post the results.
