When installing the plastic tubing to a replacement ice make water valve is there any sealant required or does the tubing just slip in?
There is usually a compression fitting that slips over the tubing.This fitting goes under the plastic nut. When the nut is tightened to the valve this fitting compresses to form a water tight connection.
there is no nut. the tubing just slips in.
My Problem/Question:I'm having the below mentioned issue with an Amana 22 (Model No. TLI22KL). My water inlet tube cracked...I've replaced the tubing but I am having a problem properly sealing the tubes connection to the water valve inlet. I don't seem to have a compression fitting that slips over the tubing (new tubing didn't come with one either). When I removed the defective tube there wasn't a compression fitting, just a spring in the tube. Can you tell me if I need to purchase a compression fitting to seal the connection? If so, do you know where I might be able to purchase it?Or, should the tubing somehow seal itself in the plastic nut? Abbie's answer: Originally Posted by: abbie  There is usually a compression fitting that slips over the tubing.This fitting goes under the plastic nut. When the nut is tightened to the valve this fitting compresses to form a water tight connection. Original Question: When installing the plastic tubing to a replacement ice make water valve is there any sealant required or does the tubing just slip in?
