pugdogJ
#1 Posted : Thursday, August 13, 2009 3:21:30 PM(UTC)
pugdogJ
The freezer of my hotpoint side-by-side is howling loudly then stops. I've read other posts, but just curious if anyone has had this problem with the same model/brand and if it is an easy do it yourself fix or easier to call someone in to repair it.
#2 Posted : Friday, August 14, 2009 1:32:20 AM(UTC)
I would check your evaporator fan motor, may have bad bearings. If ok, replace the motherboard, part # AP4436216
