Where is the damper located on a GE Profile Refrigerator, model # PDS22SISBRSS, and how would I access it?
Thank you.
In the back of the fresh food section there is an airflow tower. The damper is inside that tower. That tower and the damper are replaced as one unit (#603 on parts breakdown). You must remove the shelves to remove the tower. Then just remove the screws that hold it in. Hope this helps!
