tericribb
#1 Posted : Sunday, March 18, 2012 10:05:30 AM(UTC)
tericribb
My Bosch dryer won't heat up and dry my clothes. How do I know if it is the heating element or something else less expensive?
Joe / APP Team
#2 Posted : Wednesday, March 21, 2012 11:24:23 AM(UTC)
Joe / APP Team
Teri, First check and make sure the breakers in the fuse box are set and locked in place. Any circuit or voltage checks would require a multimeter
Part number: AP3873826
But you can remove the back panel, and check the wiring, and heater element visually. Here's some help:
"To remove electric heater:•Turn off or disconnect electric power.•After removing rear panel screws & one rear duct screw, remove rear panel.•Remove four rear cover screws & two duct screws, then lift rear cover with duct up and away from heater assembly. Disconnect wires.•Slide heater toward rear of dryer until tabs slide out of slots in dryer base."
Good Luck and Thanks,
