The Ice Maker Quit Then Started Again For About Two Weeks Then Quit, And Never Restarted, The Water Dispenser Inside The Door Works Fine, Is There Two Water Control Valves, If Not How Can Changing That Solve The Ice Maker When There Is Water Getting To The Dispenser.
It's two water inlet valve built into one.
then I also see that the filler pipe can freeze up, where does that generally occur, and how do you thaw it out.
