smplesome
#1 Posted : Thursday, August 13, 2009 6:51:06 AM(UTC)
smplesome
Issue just recently started...Dryer got really hot and smell as if something was burning...shut it off and pushed the start button to run...never heated again. Troubleshooting taken steps thus far:
Replaced heater element and thermal fuse
Cleaned out lint filter
Disconnected flexible aluminum vent-ran dryer still NO HEAT
Volt meter was reading 0.3 volts (violet wire) from Timer to the Thermostat Internal Bias...replaced Thermostat Internal Bias still No Heat..
#2 Posted : Thursday, August 13, 2009 3:22:09 PM(UTC)
The model number you posted does not come up. Verify and repost it.
