tnoel
#1 Posted : Thursday, August 13, 2009 5:51:23 AM(UTC)
tnoel
My ice-maker is not getting water even though the water hose is correctly installed. I recently replaced the ice-maker but that clearly wasn't the problem. Now a repair guy seems to think is the sensor that allows water to go to the ice-maker is faulty. Can someone assist me in solving this problem.
Any suggestions as to what might be the problem here. Just a little background, the ice-maker worked very well in the past and one day it stopped working (no ice) so i called in a repair guy and he suggested that i replaced the ice-maker and i did earlier this year but the no success.
I still cannot get ice. Please help
Theresa
#2 Posted : Thursday, August 13, 2009 3:07:35 PM(UTC)
Theresa,
Does the water dispenser on the door work?
How old is the water filter?
Check the water feeding tube into the ice maker for a frost build up inside.
Post the results.
- The water filter Part number: AP2539088
tnoel
#3 Posted : Monday, August 17, 2009 8:14:17 AM(UTC)
tnoel
The water filter has been also replaced the same date with the new ice-maker. I defrosted the fridge yesterday to allow any ice in the line to melt. But i still can't get any ice.
What else can i do?
#4 Posted : Monday, August 17, 2009 4:36:05 PM(UTC)
Locate the water inlet valve on the back of the refrigerator. Swap the wires between the ice maker solenoid (1/4" plastic tube) and the water dispenser solenoid. Push the water release lever on the door and watch if the ice maker filled up with water.
Post the results.
- The water inlet valve Part number: AP4298908
