i have an amana heavy duty gas dryer it worked last night and now i cant get any heat no flame or nothing but the catch is that when i tap on the thing the gas line connect into or the ignitor assembly it will spark i did get it to glow for about 45 seconds then it flickered and went out any ideas
check your main and pilot solenoid valve.
If you see ignitor on, the problem is coil valve.
