gcstexas
#1 Posted : Friday, January 11, 2008 10:55:47 AM(UTC)
gcstexas
I would like to know where I can get the parts I need to convert my Roper propane stove to natural gas.:confused:
bentwrench1999
#2 Posted : Friday, January 11, 2008 11:31:23 AM(UTC)
bentwrench1999
From the break down I saw, you ADJUST this model, not convert. If it's already set up for Propane, reverse the procedure to revert back to nat. gas. Reverse the regulator cap, then open up the orifices with a 1/2" open end wrench. You will also need to adjust the bake and broiler orifices also...also, there may be a setting on the thermostat. It'll be stamped with something like a L on top and a N on the bottom. Move it to N..wrench:)
sundae
#3 Posted : Friday, January 2, 2009 10:58:11 AM(UTC)
sundae
how do i get to the regulator cap
