We own a Kenmore Elite french door with bottom freezer, Model #795 77556600 (is this an LG also?). The light won't light even though the bulb is not burned out ...when upper door is open on the right and I poke the switch it flickers. It won't flicker on the left. Is it the switch or is it in the circuit board?
Very likely the problem is a bad light switch. It is located under the door hinge cover. - The light switch Part number: AP4445152
