snap683
#1 Posted : Thursday, March 15, 2012 4:24:26 PM(UTC)
snap683
Recent had the oven heating element go out; got my replacement yesterday and installed with no luck. All surface functions work with no problems. But the Broiler and the Oven heating elements aren't working. Did a voltage check when the oven is turned on and I get about 107.4 - 109.3 vac on the wires. The element itself reads about 25 ohms. I get nothing for voltage when i connect the wires to the element. I don't have a schematic of the controller but it was replaced about 2 yrs ago (T08-2K). But no fuses were blown or are blowing now. I hear a little clicking noise when I first turn on the oven then it goes away. Any ideals?
#2 Posted : Friday, March 16, 2012 2:45:29 AM(UTC)
I cannot find any info on the given model number.
Tried here and several other sites.
Trace the wires to the controller and also from the controller to the elements.
Some units have a thermal fuse in the line to the control or to the common wire to the elements.
I do not know if the unit tells you the actual temperature or if it has a preheat indicator. If it does check that the unit is actually in preheat.
If the oven sensor goes sometimes the unit will think that it is already at set temperature and therefore will not heat.
Here is a good site with general stove repair info.
http://www.applianceaid.com/erange.html
Odds are that the controller has blown again.
snap683
#3 Posted : Saturday, March 17, 2012 1:50:11 PM(UTC)
snap683
Thanks for the input, but I found my problem. When I disconnected the element the first time I didn't realize there were two black wires attached and with all the stuffing the second wire had recessed where I couldn't see it until I took the wiring cover off the back. It was a second black wire coming off the electrical terminal strip completing the circuit for both the broiler and oven.
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
old Wall oven heating element problems (Oven Repair (including Ranges and Cooktops))
by shelliejh 12/6/2018 12:16:51 PM(UTC)
Need oven heating element GE # J320B1AV (Oven Repair (including Ranges and Cooktops))
by railfan777 10/18/2017 12:48:58 PM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Oven Heating Element Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by this_is_nascar 10/4/2014 1:38:26 PM(UTC)
Replacing hotpoint oven heating element (Oven Repair (including Ranges and Cooktops))
by billsee 11/29/2013 6:37:57 AM(UTC)
Need help with range digital display after replacing oven heating element (Oven Repair (including Ranges and Cooktops))
by brewbaker 12/27/2012 3:11:57 PM(UTC)
new oven heating element will not heat (Oven Repair (including Ranges and Cooktops))
by Johnwg 7/15/2012 1:08:39 PM(UTC)
oven heating element popped (Oven Repair (including Ranges and Cooktops))
by howie b. 6/25/2012 3:26:59 PM(UTC)
Oven Heating Element Split In Half! (Oven Repair (including Ranges and Cooktops))
by marinakiser 12/10/2011 4:36:11 PM(UTC)
G.E. oven heating element installation (Oven Repair (including Ranges and Cooktops))
by gloria Oliphant 10/24/2011 10:58:44 AM(UTC)
Oven Heating Element Cracked (Oven Repair (including Ranges and Cooktops))
by clramey 7/11/2011 3:00:12 PM(UTC)
Oven heating elements do not work (Oven Repair (including Ranges and Cooktops))
by Packy62 2/23/2011 8:57:48 AM(UTC)
How to replace oven heating element? (Oven Repair (including Ranges and Cooktops))
by ssananikone 1/7/2011 7:49:00 PM(UTC)
Oven Heating Element to be replaced (Oven Repair (including Ranges and Cooktops))
by ems633755 11/29/2010 4:47:04 AM(UTC)
