2 Pages12>
estersonpt
#1 Posted : Thursday, March 15, 2012 7:06:09 AM(UTC)
estersonpt
On the display panel, most of the buttons still light up (heated dry, delay time, etc), but the ON button area in the center of the panel does not light up and therefore the dishwasher won't start/run. Interestingly, about a week ago, I sort of pushed the panel upward while I pressed to START button and the dishwasher started working. Strange....do I need a new control panel or something else????
#2 Posted : Thursday, March 15, 2012 3:24:36 PM(UTC)
Carefully disassemble the control panel and verify proper connection of the ribbon cables connected the key panel and the control board. Give it a try.
estersonpt
#3 Posted : Sunday, March 18, 2012 8:43:00 AM(UTC)
estersonpt
Wow! Thanks, Gene. You are correct. When I removed the door panel screws and manually pressed the ribbon bar connector in against the pins, the START button works. I sort of have to push it in and upward to get it working.
Thanks!
OK, now that we know that it is a ribbon-to-pin connection problem, how do I fix the "pin bar" to remain pushed all the way in. It seems that the little clip connector does not quite keep it all the way in.
#4 Posted : Monday, March 19, 2012 11:18:49 AM(UTC)
The problem can be a bad key panel (the ribbon cable coming out of it is not repairable) or a bad connector at the control board. If you can not determine which parts is bad, then replace the control panel first.
I can not find the model number with SS at the end. The closest model numbers I found ended with BB, CC or WW.
estersonpt
#5 Posted : Monday, March 19, 2012 12:05:00 PM(UTC)
estersonpt
Here is the correct model number (the one shown is an error):
PDW 7880 J0 1SS
The ribbon is part of the key panel, right?
The ribbon does not seem to disconnect from the key panel. So I have to replace the whole ket panel (about $250).
What is the name (number?) of the part that the ribbon strip pushes into? The black box.
Thanks again.
#6 Posted : Monday, March 19, 2012 1:21:53 PM(UTC)
This "black box" is actually the electronic control board. I understand that the key panel is very expensive but I would recommend to replace it first.
- The control panel Part number: AP3794426
estersonpt
#7 Posted : Monday, March 19, 2012 2:46:52 PM(UTC)
estersonpt
Thanks again, Gene. I actually ordered both parts. I will try the "control panel" (the key buttons panel) first and if that doesn't work, I'll replace both parts. Thanks.
Sam
estersonpt
#8 Posted : Monday, March 19, 2012 2:47:32 PM(UTC)
estersonpt
Gene,
Is there any "rocket science" to replacing both of those parts. It looks like a few screws. Anything to worry about? Thanks again.
#9 Posted : Monday, March 19, 2012 3:11:32 PM(UTC)
I don't think it can be a difficult job. Keep us posted.
estersonpt
#10 Posted : Tuesday, April 17, 2012 6:16:16 PM(UTC)
estersonpt
Gene:
Thanks for the great advice.
I replaced the key button control panel first as you suggested (~ $310) and it works like a charm.
Sorry it took so long to post a reply but the part was back ordered since last month and I just received it today!
Sam
2 Pages12>
