boomer913
#1 Posted : Wednesday, March 14, 2012 1:13:25 PM(UTC)
boomer913
Oven and broiler not working
#2 Posted : Thursday, March 15, 2012 3:13:04 AM(UTC)
Replacement parts for Kenmore 79094320300 | AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...pringfield/316255311.pdf
I am assuming that the stove top elements work OK.
If the unit has no other symptoms then odds are that the control board is toast.
I would unplug it and check that tghe wires to the elements and the board are OK.
Also I would check the oven sensor though if it was shot you would probably see a wrong oven temperature.
Here is a good link on it.
Check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
Guest (4)
Oven and Broiler not working (Oven Repair (including Ranges and Cooktops))
by Broncojo 5/22/2015 4:03:12 PM(UTC)
Tappan oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by mrthtolan@yahoo.com 10/15/2014 6:44:08 AM(UTC)
oven and broiler not working, need part (Oven Repair (including Ranges and Cooktops))
by Todd F 9/24/2014 6:16:39 PM(UTC)
by Cody Moss 6/18/2012 7:32:59 PM(UTC)
Oven and broiler not working (Oven Repair (including Ranges and Cooktops))
by boomer913 3/14/2012 1:00:22 PM(UTC)
by JimConlon 12/13/2011 10:22:01 AM(UTC)
Oven And Broiler Not Working (Oven Repair (including Ranges and Cooktops))
by MACH1MUSTANG 1/20/2010 1:30:33 PM(UTC)
oven and broiler not working the stoetop does (Oven Repair (including Ranges and Cooktops))
by markk 2/5/2008 7:02:15 PM(UTC)
