dishwasher will only drain half the water out
Originally Posted by: stoney.72  dishwasher will only drain half the water out Stoney, A few things to check first. Remove and check the filter Part number: AP4484686
for debris and hard water or detergent deposits. Remove the sump cover/filter Part number: AP4484685
check those for the same, and look and carefully feel inside the sump and clear it out as well. Disconnect the drain hose from the disposal or sink drain connection and drain the dishwasher into a bucket, this will clear most of the debris in the drain system. If the problem persists, you'll need to dismantle the pump assembly and check the impellers for damage. Thanks, :) :) :)
