KAGAR59
#1 Posted : Wednesday, March 14, 2012 6:58:23 AM(UTC)
KAGAR59
I need to replace the water piping that runs up through the freezer door to the front water dispenser. It is leaking inside my freezer door and running out. How dose the front dispenser panel come off to repair?
Joe / APP Team
#2 Posted : Wednesday, March 14, 2012 10:23:13 AM(UTC)
Joe / APP Team
Kagar, You don't need to dismantle the dispenser. You have to remove and dismantle the freezer door. Heres some help :
Freezer Door Water Tube
1. Remove freezer door.
2. Remove inner door liner
3. Locate water tube next to left flange of door. Water
tube runs inside large plastic sleeve.
4 Free tube from cavity and slide water tube down and out
through hole in door closure.
You do need to be careful.
Thanks and Good Luck,
