jcpendergast
#1 Posted : Tuesday, August 11, 2009 8:49:44 AM(UTC)
jcpendergast
Hi folks: Our Kenmore gas dryer starts, heats up, then shuts off after 5 - 10 minutes. I checked the high temp t stat at the exhaust port and linear t stat above it for continuity, and they both read closed. Any suggestions? Thanks, Jim
jcpendergast
#2 Posted : Monday, August 17, 2009 7:00:45 AM(UTC)
jcpendergast
Hi folks:
I found the fix for this. I replaced both gas valve coils (Appliance Parts Pros Part # AP3094251, $14.89), and it fixed the problem. Surgery was only about 10 minutes. Thanks to all, Jim
#3 Posted : Monday, August 17, 2009 1:25:13 PM(UTC)
Thank you for sharing your experience with us and good luck with your dryer.
