Hi guys, i've got an icemaker that quit a few days ago. Thanks to the net, i was able to put it into service diagnostic test mode which moved the paddles but, had no water. I then replaced the water filter with the bypass plug, now I get water but can't get it go into diagnostic mode. The light is flashing and am having trouble getting it to go into the diagnostic mode again.... any ideas?? Thanks for any help!!
well, removed the icemaker and let it thaw.......installed again & got ice!!!!
OK, update... got 2-3 loads of ice, now frozen but wont harvest... even service mode does not allow harvest, possible heater malfunction?? any ideas??
