Hello:D , My mothers:p Whirlpool GD25DIXHW00 refrigerator has quit making ice:confused: . If I turn the slider switch on the right side of the freezer on and off several times sometimes it will drop one set of ice then no more. Have full water pressure in the door dispenser so it has water. It made ice fine until two weeks ago. Very frustrating!:mad: Richard rburnstrash@yahoo.com
check and see if the fill tube is frozing. mayying times that freeze.
Quote:...If I turn the slider switch on the right side of the freezer on and off several times sometimes it will drop one set of ice then no more... Sounds like the problem is a bad PC optic boards because power to the ice maker comes through theses boards. - The PC board kit Part number: AP3137510
