Mary Emily
#1 Posted : Monday, August 10, 2009 3:20:27 PM(UTC)
Mary Emily
When my parents died I took their washer. I don't how old it is. I called "Mr. Appliance" and was told it could be 29 years old and that parts were still available. I really question that. Anyway, the machine leaks--sometimes alittle, sometimes alot. Plus now it does not spin all the water out. Sometimes there is two inches of water, sometimes bubbley foam only. Is the machine worth fixing ? I really like it but maybe something else will go wrong next if I do fix it.
#2 Posted : Tuesday, August 11, 2009 2:38:43 AM(UTC)
I would pull off the front panel and check where the leak is, probably from the tub. If so, it probably is not worth fixing.
