yzhong
#1 Posted : Monday, August 10, 2009 12:13:23 PM(UTC)
yzhong
My dry ran but no heat. After replacing the fuse, thermostat, and ignitor, when I turned on the dryer by closing the door and pushing the Start button, the new igniter was NOT burnt to red, i.e., I did NOT get a glow in the ignitor. The dryer still ran but no heat. Is there a problem of electric circuit? If so, what to do? Thank you. Adam
magician59
#2 Posted : Monday, August 10, 2009 3:03:51 PM(UTC)
magician59
Open it up and check to make sure you properly and securely reconnected the wire connectors. If everything is OK, take the wires off the flame sensor and tape them together very securely, making certain they can't come into any metal contact. Start the dryer to see if you now get a glow and a flame. If so, replace the sensor.
