adamson
#1 Posted : Sunday, August 9, 2009 3:11:05 PM(UTC)
adamson
Dryer won't heat up. Had this problem earlier with auto-sense side of switch, but would work on the timed side. Finally quit on timed side. Installed new switch, but now won't heat anywhere. It also won't move as time goes by. Just curious what to look for. thanks
adamson
#2 Posted : Sunday, August 9, 2009 4:34:04 PM(UTC)
adamson
Tried dryer after posting and it would heat with a few dry clothes in it. Put wet towels in it and it wouldn't heat anymore. What to look for???
magician59
#3 Posted : Sunday, August 9, 2009 4:51:30 PM(UTC)
magician59
First thing to check is the power outlet. Make sure you're getting the proper voltage. Then select a timed dry cycle and just monitor the timer to make sure it advances. If there are multiple timed cycles, do this in each. Post your results.
adamson
#4 Posted : Wednesday, August 12, 2009 5:59:32 PM(UTC)
adamson
checked fuses and had one bad. Didnt know it would run and not heat with low power, figured it wouldn't do much of anything thanks for the help.
No Dryer Heat/No shut of in auto cycle (Dryer Repair)
by fred2117 4/30/2009 2:09:57 AM(UTC)
No Dryer Heat (Dryer Repair)
by jackd3 10/6/2007 5:06:10 AM(UTC)
by Warren 8/7/2007 10:34:27 AM(UTC)
