AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Only on rinse cycle washer won't fill up with water, goes right to the drain hose
Why is it only on the rinse cycle, that the washer begins to fill with water but never fills. Lifted the drain hose out of the drain and it is going straight to the drain. It was doing this for about 2 hours before I realized it. What is causing this and why only on the rinse cycle?
What is the complete model number of the washer?
If it is less than a year old then call for the warranty service.
Washer Repair
