We have water to the bottom of the freezer door but no water dispenses when the spout is pushed. What causes this and how can it be fixed?:confused:
Locate the water inlet valve on the back of the refrigerator. Remove the wires from the water dispenser solenoid (5/16" tube) and check for 120 VAC between these wires while the dispenser on the door calls for water.
Post the results.
