The ground fault breaker trips when the refrigerator door is opened...so the problem is either in the switch or the light fixture (I have removed the light bulb). The part number for the switch is AP3132744.... I would like to try replacing the switch first…how do I remove the switch?
Originally Posted by: budkeene  The ground fault breaker trips when the refrigerator door is opened...so the problem is either in the switch or the light fixture (I have removed the light bulb). The part number for the switch is AP3132744.... I would like to try replacing the switch first…how do I remove the switch? The ground fault breaker trips when the refrigerator door is opened...so the problem is either in the switch or the light fixture (I have removed the light bulb). The part number for the switch is AP3132744.... I would like to try replacing the switch first…how do I remove the switch?
