AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Excessive sweating between bottom of freezer door and top of fridge door
I replaced all door gaskets last winter because I would occasionally find a small puddle of water on the floor just below the door opening. Now that it's humid and hot, the door is sweating excessively; moisture can be seen just below the freezer door where is accumlates then drips down the bottom door to the floor. If I don't keep a paper towel on the top of the bottom door, the water literally fall on me when I open the door to get anything out. The new gaskets are GE parts, look correct and tight and a flashlight inside the fridge does not show any light.
Any suggestions on how to handle this short of replacing the gaskets again?
you may have an mullion heater problem. check, if you have a energy saver swicth.
