Dishwasher takes too long. Water temp @130 degrees. Sanitize light does not come on. Dishes seem to be clean. Tried new heating element. Did not resolve. Any suggestions.
Groups: APP Team
Hi. How long is too long? What cycles are you using? Does the sanitize light comes on at any cycles? The 130*F is a bit too low. Will you be able to check for 120v at the heater? If there is 120v then you should check the thermistor. At the control board unplug connector j5. Measure resistance between P1 and p3.You are looking for 10 Kohm @77*F or 2,4 Kohm @140*F. The thermistor Part number: AP4113421
