My washer's timer will not advance. I can reset the timer to the specific function I need done such as spiining, filling to rinse... and complete the cycle manually. Everything else seems to work fine, just the timer never moves from where I set it. Any help appreciated. TKS Diane Jacobs
Originally Posted by: djaco4749 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My washer's timer will not advance. I can reset the timer to the specific function I need done such as spiining, filling to rinse... and complete the cycle manually. Everything else seems to work fine, just the timer never moves from where I set it. Any help appreciated. TKS Diane Jacobs Djaco, You've got a mechanical or electrical breakdown inside the timer, and you'll need to start there and replace the timer. Unfortunately, the model number you supplied is incorrect, and we could not research your part needed. Good Luck and Thanks, :) :) :)
