scully27926
#1 Posted : Saturday, August 4, 2007 10:55:36 AM(UTC)
scully27926
I have a Kenmore front loader that is just over one year old. The entire cycle advances too fast, in about two minutes (the timer moves all the way around, water comes out, it spins a little, and then stops) and as a result, the clothes do not actually get clean. What part do you think is broken?
#2 Posted : Tuesday, August 7, 2007 7:28:47 PM(UTC)
scully27926
Most likely the problem with your washer is a bad timer. It is not repairable and has to be replaced.
The part number for the new timer is AP2107661
Good luck.
