We have a GE Profile Arctica that makes ice but does not dispense water. My husband took the relay assembly in the back out and tapped the relays. After putting it back together it worked for about a half hour then quit again. My Dad put us onto the relay because he had a Kenmore that did the same thing. Do you think it's the relay or something else and should we just replace the whole assy. for easier repair? Thanks...Belle:)
Also, I saw a similar issue with another person and you mentioned replacing the filter. I'm just curious as to whether the filter wouldn't keep the water from going to the icemaker also. Thanks again.
Your tank may be frozen up... or your lines. There's a kit you can buy to prevent this from happening. Take a hair dryer and heat the tank. First, pinch the water lines leading to and from the tank. If it is frozen up, you'll be able to tell by pinching the lines.
I have a GE side by side with water and ice dispenser. The water will quit dispensing. What I found the problem to be is the water line in the door is frozen. I cut a panel out of the inside of the freezer door, cut away the insulation and used a hair dryer to unfreeze the water line. You can test to determine if the water line is frozen. At the bottom of the freezer door there is a connection that is easy to take apart, then activate the water. If you get water running at that point, your line in the door is frozen.
Originally Posted by: Maribel Lumangdag  We have a GE Profile Arctica that makes ice but does not dispense water. My husband took the relay assembly in the back out and tapped the relays. After putting it back together it worked for about a half hour then quit again. My Dad put us onto the relay because he had a Kenmore that did the same thing. Do you think it's the relay or something else and should we just replace the whole assy. for easier repair? Thanks...Belle:) I have the same problem. I've disconnected the line at the bottom of the freezer door, activated the water lever, and no water comes out. I also checked the water resevoir inside the fridge and it's NOT frozen. When I push the water lever, I can hear the relay/solenoid activate in the back, but no water. Any other ideas/suggestions?
