Good Morning Everyone...! All led lights are out on my dishwasher, however, it responds and runs when specific touch pads are pressed. Would this be control board or control, touch pad panel? Any Help would be greatly appreciated! Thanks Chuck
Originally Posted by: Chuck Sinclaire ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Good Morning Everyone...!
Thanks Chuck Chuck, We're glad you got the rinse dispenser taken care of. When you had the door assembly apart, are you sure you didn't disturb the tracer ribbon from the control panel to the control board. Part number: AP3136031
You may want to check and clean the insertion end of the ribbon and re insert it into the control board connector. If the problem persists, you'll need to replace the control panel. :) :) :)
I took the rinse dispenser out while the door panel was open when I was trouble shooting the No leds. I figured I would clean that issue up while the door was open. I checked the Fuse and looked for obvious signs of trouble. I'm going to try to clean up the connection at the ribbon cable..., but I thing the control panel is toast. Thanks!
Originally Posted by: Chuck Sinclaire ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I took the rinse dispenser out while the door panel was open when I was trouble shooting the No leds. I figured I would clean that issue up while the door was open. I checked the Fuse and looked for obvious signs of trouble. I'm going to try to clean up the connection at the ribbon cable..., but I thing the control panel is toast.
Thanks! Chuck, I had it backwards, dispenser then the LED'S. With the LED's being the issue, and evrything else working, that pretty much isolates the issue to the LED light circuit in the control panel. We sent you the part number for it in a prevoius post, so you should eb set and ready. Thanks, :) :) :)
